Deletes internal resources for the specified RSVP-TE LSP.
| lsp_name | Specifies the LSP within the switch to be deleted. |
| all | Deletes all RSVP-TE configured LSPs. |
N/A.
This command deletes internal resources for the specified RSVP-TE LSP. The LSP is first withdrawn if it is currently active. Deleting an LSP may cause a PW to fail. Any static routes configured to a deleted LSP are also removed.
The following command deletes the configured RSVP-TE LSP named lsp598:
delete mpls rsvp-te lsp lsp598
This command was first available in ExtremeXOS 11.6.
This command is available only on the platforms that support MPLS as described in the Switch Engine v33.1.1 Licensing Guide document.
